跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
Screen fault // logical board - working when closed
Hi
Firstly thanks for taking the time to read this. My A1502 13” was working fine, until I shut the lid followed by a unfortunate drop, no more than 5/6 inches onto a rug. I thought nothing of it due to the lack of height and visually didn’t seem too destructive.
I was then greeted by a black screen upon reopening a few hours later.
Now, in terms of troubleshooting, I have done all the required resets, as well as opening the back up, taking everything out and rebuilding. I did not remove the trackpad or batteries.
I can get the laptop to work with no issues when using and external monitor via HDMI. I I also have to have an external keyboard/mouse connected and have the lid closed (I have to quickly shut the lid upon powering on). If I try to open the lid once logged in it will cease to work correctly, and freezes. Another observation, on initial power I have no keyboard backlight, but do have a green-light on the caps lock.
Now my question is to what the issue is and what component/s may I need to replace to get this rectified.
Thanks,
Ollie
Edited for grammar!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
@danj and @mayer are the experts on these types of problems.
完成的
Thanks! Hopefully will hear from them.
完成的
添加一条评论
1个答案
已选择的解决方案
These retina screens are very fragile with just about 1mm thickness and it takes very little to break them..a few inches distance bump was probably enough to create an internal short on top of breaking it. When you close the lid, power to the screen gets cut off and Mac can work. If you can live using it with external monitor you can try unplugging screen from the logic board, but if you want to use it as laptop there’s no other solution but replacing the assembly, replacing screen only is very difficult and might be unsuccessful in the end.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ollie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 86
