跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
This person said that motherboard of iPhone can't be replaced
Hi,
I don’t understand why this person (his name is Dr. Adriano) said that motherboard 32 GB of iPhone SE can’t be recplaced with a motherboard of 64 GB.
Please, read here: https://clinica-iphone.com/consigli-drad... - Use translator if you can’t understand italian language.
Anyway, why a Dr. said this thing, but in this forum I readed many times that is possible replace a motherboard 32 GB of iPhone SE with another motherboard 64 GB that also this is for iPhone SE? Which is verity?
Thank you in advance for reply.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
What is the model number of your SE? A1662, A1723 or A1724
完成的
A1723. The model is A1723 for iPhone SE with 32 GB and for iPhone SE 64 GB. In this case, can I replace motherboard 32 GB with 64 GB or there are problems?
完成的
添加一条评论
3个答案
最有帮助的答案
@pikachu95
Yes you can swap the board for as long as they are for the same model.
Not sure what the Dr. is referring to. Go ahead and swap your board.
这个答案有帮助吗?
得分 4
3条评论:
A1723. The model is A1723 for iPhone SE with 32 GB and for iPhone SE 64 GB. In this case, can I replace motherboard 32 GB with 64 GB or there are problems? Read this: iPhone SE is broke after charge in the car - If I want recover my data, I need to put that motherboard and I hope that someone repair it, but if I put motherboard of 64 GB that is broke in the body of iPhone SE (same model with 32 GB) is better because I'm sure that others components of iPhone SE born with 32 GB work perfectly, so if they repair motherboard I can have again my data and backup them with iTunes.
完成的
Yes you can. For as long as it is the same model there will not be any issues.
完成的
@pikachu95 No idea why such "Doctor" would answer no, but he's wrong and @oldturkey03 is right, logic boards are exactly the same size and can be swapped. If you want to recover data from your broken iPhone, unless you have an iCloud backup, you'll have to find a reputable lab into microsoldering where they can repair the board to the extent data can be recovered, if feasable.
完成的
添加一条评论
There are people that tell you you can charge up your iPhone by putting it in the microwave, but I wouldn’t try it.
这个答案有帮助吗?
得分 2
3条评论:
完成的
Apple iPhone SE (Global/Sprint/A1723) 16, 32, 64, 128 GB* Specs
Identifiers: iPhone SE - MLM32LL/A* - iPhone8,4 - A1723 - 3042*
https://everymac.com/systems/apple/iphon...
完成的
Dang it Mayer, why didn't you tell me this before...no wonder my iPhone is a charred mess :>).
完成的
添加一条评论
You should be able to,as long as your skilled enough to change the boards. Also are you sure its the right motherboard?
这个答案有帮助吗?
得分 0
1条评论:
Yes, I can, but read my question. I asked why a Dr. said a thing and why others Dr. S said another thing.
完成的
添加一条评论
添加你的答案
Patrizio Masini 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 158
