跳转到主内容
Background information about the device "Logitech G602" (wireless gaming mouse).
Mouse wheel is not scrolling
I have a problem with my mouse scroll wheel. The scroll is not working at all but the wheel clicks just fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I have recently started having this problem. I was sold it as brand new. It was working and it just stopped scrolling. Middle button works, but no scroll. There's no dirt or anything.
完成的
添加一条评论
6个答案
最有帮助的答案
Logitech G602 Scroll Wheel Replacement
这个答案有帮助吗?
得分 3
2条评论:
@ramirocampa Thanks for your help. The problem is not in the mechanical side of the scroll. When I scroll the wheel, it rotates well. The issues is that rotation doesn't get captured or sent to the computer i.e. no action happens
完成的
it might be a problem between the wheel and the digitizer. usually back in time there was a digitizer usually near the axis of the wheel. i dont know if it is suitable in your case but you might take a look at the "gears" or anytype of physical damage between the axis of the wheel and the support of it. in other mouses may be a worn out plastic axis... instead of being square shaped or any desired form it may be damaged (like too roundy) i hope this helps.
Regards
完成的
添加一条评论
I had the same issue. Took it apart, and found the wheel clogged up with cat hair. Cleaned that up and it’s working again. Thanks for the pics on how to get it apart though :)
这个答案有帮助吗?
得分 1
添加一条评论
scroll wheel was intermittent. Opened as above, removed ball of lint with tweezers from wheel area. Immediately worked correctly. Spudgers not necessary for this repair. Fingernail worked great.
PERFECT answer for my variety of this problem!
这个答案有帮助吗?
得分 0
添加一条评论
First i was thinking it doesn't work because of software. I uninstalled everything, but it didn't help .
Thank you. was dirty inside. fixed
这个答案有帮助吗?
得分 0
添加一条评论
Open it up (look for a yt tutorial if in doubt) and take it from there
这个答案有帮助吗?
得分 0
添加一条评论
Well I will suggest you to check out the following: https://www.systweak.com/blogs/logitech-...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
eng_m_hamda 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 37
总计 7,108
