跳转到主内容
加入维修社区 - 创建账户
Patagonia 外套能让你在凉爽的天气保持温暖,在潮湿的天气保持干爽。维修难度从简单的破损修补到更复杂的挡风板维修不等。
Old rain jacket delamination
Hi,
I have an older (6 years?) rain jacket that is starting to delaminate. The seams are still sealed, but the white, water repellent coating on the inside of the jacket is starting to peel off the outer. Do you have any suggestions to combat this?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
I have the same issue. Bought mine about 5 years ago, only worn in the rain, and never washed or dried it. The inner white coating is completely gone around the waist up about 3 inches and the same on the sleeves. It flakes like dandruff and is no longer waterproof in those areas, any solution from Patagonia?
由完成的
Hi @sammeybobbles, have you tried to reapply the repellant? If you scroll down a little bit an answer from Mayer has a guide on how to do it. I'm attaching the link here just in case you aren't able to find it.
Hope this helps!
如何重新涂抹持久拒水(DWR)涂层
由完成的
添加一条评论
3个答案
最有帮助的答案
See if this guide helps solve your problem:
如何重新涂抹持久拒水(DWR)涂层
这个答案有帮助吗?
得分 2
1条评论:
I’ve had luck reapplying a waterproof coating several times over the life of the jacket. Unfortunately, this problem is on the inside of the jacket and the actual lining is coming off.
由完成的
添加一条评论
I have the same issue, so i called the store if they can repair it and they said that it ‘s not repairable…But they can replace it for freeeeee! brand new jacket,it might not be the same style but, hey! its brand new Patagonia. Hope this helped you.
cheers!
这个答案有帮助吗?
得分 1
添加一条评论
Unfortunately, this problem happens constantly if it is not washed properly or very few and when it starts to happen it is inevitable, it is just ready to be recycled (I would recommend washing it at least every month if you are using it daily) and sometimes reactivate the impregnation. The next time you buy one, keep it in mind and you will be able to have it for many more years, you also have to consider how much weight and wear you gave it, sometimes you have to invest in one that has more layers (now Patagonia is doing most with three layers at a good price). I hope it helps you a little. Greetings from Berlin
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Isaac Williams 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 77
总计 11,442
