跳转到主内容
加入维修社区 - 创建账户
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
Screen brightness not changing
I recently noticed that the screen brightness on my iMac 27” 2017 model not changing, in precise, from the darkest to 30% brightness bar, it can change, but after that, it just keep the same brightness even though the brightness bar can be increased. When I do reboot, and before screen turns bright, I can see some white spots light up from bottom edge of screen, which looks different from what shows on the top edge. Running Apple self hardware test, it didn’t report any issue. So, what could be wrong, screen backlight, inverter, etc.?
Thanks in advance!
Shaun
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
@mayer Calling Dr. House of Macs, do you have an idea of what could be the problem?
完成的
添加一条评论
2个答案
已选择的解决方案
The newer iMac’s use a Buck driver which does allow a finer level of brightness. I’m suspecting the control logic is having issues with it’s stepping. You also talk about white spots of light that is either light leakage or your display has an issue.
Has someone opened your system? Have you has it serviced at some point?
Given its such a new system you likely still have warranty coverage. I would take it to an Apple Store or authorized service center to have it looked at.
这个答案有帮助吗?
得分 3
3条评论:
Apple will surely service your system if it is under warranty and you or someone else has not opened up your iMac. That might be your best bet if you under those circumstances.
完成的
Is control logic a hardware component or a software program? Thanks, I will bring it to Apple store there.
完成的
Its hardware!
完成的
添加一条评论
Hi,
It seems to be a backlight issue based on my experience with iMac’s. I know @danj know a lot about iMacs.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shaun 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 385
