跳转到主内容
加入维修社区 - 创建账户
Xbox One 手柄在2016年随着 Xbox One S 的推出而问世,并增加了对 Windows 10/11 的蓝牙支持。 该手柄修复了 Model 1537/1697 手柄上的许多设计缺陷,更加可靠。该手柄已被改进版 Model 1914 手柄所取代。
Soldering station temp setting
What would be the best temp setting for the soldering iron on a soldering station to do some soldering work on the xbox one wireless controllers?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
I keep mine set a 700 degrees Fahrenheit. You shouldn’t have to leave the iron in place for too long to get the solder to melt. You might also want to get some flux. Using flux will help the solder flow and make the whole process easier. This is great whenever you’re working on modern electronics since manufacturers use lead-free solder these days, which is much harder to melt. I recommend using 60-40 lead-rosin solder. Good luck with your repairs/modifications!
这个答案有帮助吗?
得分 5
7条评论:
Thank you very much for the info. I will give it a try
由完成的 分享
My soldering station will only go as high as 480 degrees. Is that to low? If so what soldering station would you recommend or if that is ok could I just heat up new solder on top and re- desolder from the motherboard?
由完成的 分享
If your station stops at 480 degrees that is probably in Celsius, which is about 900 degrees Fahrenheit. The station I use is made by Weller, which is very good and pretty affordable. If you set your station at about 370 degrees Celsius, you should be fine. What repairs/mods are you trying to make to your controller?
由完成的 分享
Just changing out the motherboard and daughter board
由完成的 分享
How long does your average solder take when it’s 700°F? I’m only starting out and will be slower than you but I don’t want to burn anything by keeping the iron on for too long
由完成的 分享
显示更多的2条评论
添加一条评论
添加你的答案
Rodney Brookshire 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 21
过去 30 天: 70
总计 9,557
