跳转到主内容
加入维修社区 - 创建账户
The 5th generation BMW 3 Series is based on the E9X platform. The car pictured is a E90 chassis. The E9X chassis was used from 2004-2013 when the F1X chassis was released. When talking about a non-specific chassis, this generation is typically referred to as the E9X chassis since there are multiple chassis for this generation of 3 series, depending on the body style (E90/E91/E92/E93).
Reverse Lights not working
hi i need help im driving a Bmw  e90 320i msport 2007 model, i have checked everything and i was told that it doesnt have a reverse switch or fuse for i thought if it did  i would replace the reverse light switch or fuse . please advise what to do
Update (10/05/2018)
sory forgot to mention its an automatic transmission
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi, Lance. You may have a failed or out of adjustment neutral safety switch. This switch is how the car knows electrically which gear you are in. If the bulbs themselves are good, and there is no fuse, I would start there.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Lance 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 39
总计 6,761
