跳转到主内容
The Dyson AM07 is a bladeless tower fan released in 2014. The AM07 uses "Air Multiplier" technology to create a smooth stream of air without using visible blades.
19 个问题 查看全部
Air intake on base totally clogged how to clean
On the base of the fan the intake totally clogged with dirt how do I take it apart to clean
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
1条评论
It's got loads of dust coming out the holes I have COPD and wheelchair bound so I haven't got a clue I'm on my own?
完成的
添加一条评论
4个答案
最有帮助的答案
https://www.instructables.com/id/Dyson-A...
Please see the above article I posted on how to take apart and clean the internals of a Dyson tower fan.
这个答案有帮助吗?
得分 3
4条评论:
Perfect cleaning manual!
完成的
Thanks!
If only I had remembered to take a picture before cleaning.. It was so full of dirt. as though Dyson had stuck one of their vacuum cleaners to a ring to come up with a fan.
完成的
Very good! I just wish that I’d looked online first it would have saved me so much time! I’m glad you put in that bit about the ring not being made to dissemble…….I thought it was me….I had spent ages trying to find release points but to no avail. Thank you rakone that was spot on.
完成的
Thanks! Glad my answer helped.
Do upvote it as i'm new here :)
I'll try to transfer over that instructables to ifixit soon.
完成的
添加一条评论
Vaccum with a brush attachment..obviously use a powerful vacuum..this upkeep should be done biweekly
这个答案有帮助吗?
得分 1
添加一条评论
You can remove the cover and the filter of the tower fan with the help of this video here. You can then clean the cover and/or change the filter.
https://www.youtube.com/watch?v=UXwqFhfG...
这个答案有帮助吗?
得分 0
1条评论:
No Aaron, read: AM07, NOT the Pure Cool!
完成的
添加一条评论
One way is to spray water on the inlet holes and clean the accumulated solid dust with a toothbrush.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Whojuno 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 25
过去 30 天: 100
总计 64,081
