跳转到主内容
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
263 个问题 查看全部
Where do I start with this DSi repair/rebuild?
I recently tried repairing a water damaged DSi, but gave up on it due to lack of knowledge. Now, I want to return to it, but I haven’t got a clue where to start! I’ve disassembled quite a bit of it, and I don’t know what to replace, what to keep, or where anything goes. There are some things I am sure I need to replace, and I already have a replacement motherboard and battery. Can anyone steer me in the right direction?
Parts I’m sure I need to replace:
Parts I hope I can still use but am unsure about:
Parts that I am sure I can reuse:
If you need absolutely any more information, I will be happy to provide anything you may need to help. This is the first time I have ever touched the forums here, so if I did anything wrong in terms of convenient formatting, tell me. Thanks!
-Dawn de Era
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi!
Welcome to our forums.
Before replacing anything, I would first clean all components with 90%+ isopropyl alcohol (like this one) and some Q-tips. Make sure to remove the corrosion (or gunk in general) where ever you see it. Then I would reconnect the parts without using any screws, just to see if it’s working and what’s broken.
I would however avoid using that battery since it’s been water-damaged (link to replacement). Another thing I am worried about is the power board (the one from the 1st pic) and the motherboard.
Use out teardown guide if you need more help with disassembly/ assembly: 任天堂DSi 拆解
And keep me posted of you need more help.
这个答案有帮助吗?
得分 4
2条评论:
The motherboard and battery are both spares, so they're fine. The power board I definitely have to replace. Thanks for the tip about cleaning the corrosion, though! I will definitely keep that in mind! Also, where would I find a replacement power board? I would have tested the one I had, but it was bent and I had accidentially snapped the ribbon cable.
Thanks for the help, though!
完成的
Hi!
I've seen one on Amazon: https://amzn.to/2zOzh2C
完成的
添加一条评论
添加你的答案
Dawn de Era 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 105
