跳转到主内容
加入维修社区 - 创建账户
带有轨道的托马斯小火车电池驱动骑乘玩具。
Not working at all
I have just been given this by my sister. I have had the train on charge for few hours but nothing no led, music, movement, just nothing all the components and connections look OK. How can I find the issue to fix the train. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Hey, Kelly. Do you have a multimeter?
由完成的 分享
Hi yes I do own one
由完成的 分享
It is working for music but not moving
由完成的 分享
添加一条评论
1个答案
已选择的解决方案
Here's a teardown of the train. With the charger unplugged, set your multimeter to DC Volts and measure the voltage of the battery at the battery terminals. It should say on the side of the battery what the voltage is supposed to be. If the battery measures the correct amount, measure the voltage again with the black lead on the negative battery terminal and the red lead on the far end of the red wire. I would think it terminates at the back of the switch. If there is no voltage there then the in-line fuse is blown and will need to be replaced.
托马斯电动小火车 - 系统图及组件
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kelly Kennedy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 57
总计 2,667
