跳转到主内容
加入维修社区 - 创建账户
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
Activate issue with no network works
Hello!
I have iphone 7 (A1660) with (NO service) problem , I tryed use ipcc files but carrier still Not Available, so I update to IOS 12 and now I stuck with activate issue(there is still no service,Even with use different sim cared), it saying Unable to Activate An update is required to activate your iphone. image below
I Noted when I eject the tray of sim cared, my phone do’s not say (No SIM card inserted ).
pleas help me!
Thank you before!!
Ibrahim
回答此问题 我也有这个问题
这是一个好问题吗?
得分 15
1条评论
I have same problem too
完成的
添加一条评论
8个答案
最有帮助的答案
I solved that issues by changing BBPMU IC on iPhone 7 and restore via iTunes then my problem solved.This videos help me to find the solution.Hope this works.
这个答案有帮助吗?
得分 3
3条评论:
where is the video? I really need your help sir, I got this problem for a month now
完成的
where is the video
完成的
@aresmuzamel
@MAKE
Click on solution to get video
完成的
添加一条评论
This is a known issue with the iPhone 7 modem. Send in for repair with Apple: https://www.apple.com/support/iphone-7-n....
这个答案有帮助吗?
得分 2
1条评论:
Apple says the fix it for free until you send them the device. I had the same issue and Apple says that my iphone needs a new screen due to a very little scratch and they are charging me 316+tax for that, so they fix the activation issue. Bottom line, they fix everything with the phone or nothing, you have to pay for the cosmetic issue so they fix the activation issue for "free". Scam
完成的
添加一条评论
I had this issue with iPhone 7.
Did a chat with apple representative and they had me go to my iTunes and make sure I was updated first. Then turn phone off and connect to computer. Then open iTunes and let it install update.
It didn’t work.
She next had hold down the power and volume up button for about a minute or two until your phone shows that it is connected to iTunes, then the iTunes screen on my laptop was showing that it was extracting, then when it was done it started to update.
Phone turned off after installing and I was able to set my phone up.
这个答案有帮助吗?
得分 1
添加一条评论
some people with this case get their phone back with changing baseband power ic on the machine board. May be y’all wanna try it too.
这个答案有帮助吗?
得分 0
添加一条评论
ich habe problem men iphon gleich ist was maen bite
这个答案有帮助吗?
得分 0
添加一条评论
if the model is of those : A1660, 1680 , A1779 then there is no issue coz apple said it, you can read this link :https://support.apple.com/iphone-7-no-se...
这个答案有帮助吗?
得分 0
添加一条评论
Fixed by adding another device to my account(iphone 6) then i removed my iphone 7 from list of trusted phones. That allowed me to activate.
这个答案有帮助吗?
得分 0
1条评论:
could you explain it a little bit more?
完成的
添加一条评论
My iphone 7 unable to activate
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ibrahim Hassan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 21
总计 21,980
