跳转到主内容
加入维修社区 - 创建账户
针对改进型第一代 Ranger 紧凑型皮卡的维修指南和技术支持。Ranger 在 1989 车型年进行了改款和一些机械结构更新。
4 years without being started
Just replaced the fuel pump ,battery and emptied the gas tank put new gas but it still wont turn over , spark plugs are good as well as the coils and along with the spark plug wires& new relay . The fuses are good .has an after market alram system that no longer works with the clicker batteries were replaced .any one whos dealt with this kind of problem id appericate some help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Phillip Griego let us know what works. Do the lights come on? Do you have any sign of life on your Ford?
由完成的 分享
You said it wouldn't turn over. Do you mean there is no "cranking" when you turn the key, or that there IS cranking, but it does not start?
由完成的 分享
添加一条评论
1个答案
You may need to pull the plugs and carefully hand crank the engine to break the vacuum seals and varnish buildup on the cylinder walls & pistons. When you store a engine for over 3 months you really need to add in an additive to the gas and fully fill the tank and you need to put oil into the cylinders to coat the walls (doesn’t take much).
Edmunds - How to Prep Your Car for Long Term Storage
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Phillip Griego 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 330
