跳转到主内容
The HP Deskjet Ink Advantage 1515 is an all-in-one desktop inkjet printer/scanner by HP. Model number B2L57A#AKY.
Black Ink Keeps on Blinking
I’ve tried to replace two new black ink but problem is still there.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
4条评论:
Hi @johnhenryg ,
Don’t know your printer but is there a ink level “reset” option at all in the printer’s properties section of your computer?
完成的
Yes, I did tried the reset option even pressing down both cancel and power button after the blinking stops but after test printing it goes back to error state.
完成的
Sir John is your problem solve? teach me the solution, i got the same problem of yours of my printer. thank you..
完成的
Nope, it didn't resolved I just put it on junk and plan it to trade to buy new printer.
完成的
添加一条评论
2个答案
Are you using genuine ink cartridges that have not been “re-filled” or tampered with at all? I do know some printers that completely shut down when non-genuine ink is added.
这个答案有帮助吗?
得分 0
1条评论:
yes I already bought 3 from different stores and even scan using the qr code.
完成的
添加一条评论
  1. Hold On/Off button for 1 second
  2. Hold Cancel button for 2 seconds
  3. Release both buttons together
  4. After 3 seconds, it will print a test pattern
  5. Immediately, print whatever you want to print
If the problem persists, repeat those procedures before printing something.
这个答案有帮助吗?
得分 0
1条评论:
this is just a temporary solution for each time printing.
完成的
添加一条评论
添加你的答案
johnhenrygaspay 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 12
总计 3,757
