跳转到主内容
The BlackBerry Storm is RIM's first touchscreen device, and its first without a physical keyboard.
2 个问题 查看全部
Broken ear jack. How do I replace the broken part?
Hi,
I have a blackberry storm 9530 (device software: 5.0.0.328). My phone is no longer under warranty and I need to replace my stereo ear jack. I have searched all over the web and cannot find a resource that provides detailed information explaining and showing how to replace this part.
Can you help?
Your assistance would be greatly appreciated!
Thank you, Steve
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Okay, first here is a link for the actual jack Then here is a partial teardown of the Storm. There are even a couple of videos on youtube.com that can help you to disassemble your Storm. Once you have it apart I am sure you can figure out how to install the jack. Good Luck and hope you take plenty of pics for a new guide. Let us know how it is going.
这个答案有帮助吗?
得分 1
4条评论:
+ that partial teardown looks pretty complete to me
完成的
:-) I called it partial because it does not show specifically how to change the audio jack
完成的
I very much appreciate all of your input! Does anyone know how the stereo ear jack is removed? Do I need a solder gun to remove and replace the jack?
Thanks a bunch!
完成的
Steve not quite sure but the storm has a ribbon cable that connects all of the connectors etc. I guess you will have to disassemble it to make sure. It is always good to have a bit of knowledge about soldering when working with those devices. Let us know and we can continue to guide you through that.
完成的
添加一条评论
添加你的答案
Steve 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 13
总计 1,629
