跳转到主内容
加入维修社区 - 创建账户
Tecno Y3s 安卓智能手机由 Tecno 于 2015 年 4 月发布。
phone has a problem charging
i've assesed a clients phone and the charging jack is okay, but the phone still has a problem charging..where should i look?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 20
2条评论
i've assesed a clients phone and the charging jack is not okay, but the phone still has a problem charging..where should i look?
由完成的 分享
Sir, my mobile battery is very weak, what should I do to get it fixed?
由完成的 分享
添加一条评论
7个答案
最有帮助的答案
You should check the connections from the Socket Charging to the C - Power Bauur inside the device and your money using a device called Avoometer
这个答案有帮助吗?
得分 3
添加一条评论
You can replace the charging socket witch is probably damaged unfortunately ifixit doesn’t have a guyed for it so look on YouTube for a guyed and i would say to go to eBay for the part
这个答案有帮助吗?
得分 3
添加一条评论
To take a look on battery terminal if a well connected second to check life of battery
这个答案有帮助吗?
得分 0
1条评论:
Take a carefully look at the battery terminals if we'll connected, you can as well try boosting the battery if situation persist try replacing the battery.
More technical you can run a jumper from the positive terminal of the charging legs to the vbat.
由完成的 分享
添加一条评论
Phone is not power on and showing logo
这个答案有帮助吗?
得分 0
1条评论:
@yashdahiya your phone is a Tecno Y3s? What have you checked? Anything happened to the phone? Did it get dropped or any water damage?
由完成的 分享
添加一条评论
My phone charging socket is not working
这个答案有帮助吗?
得分 0
添加一条评论
No problem my phone is ok
这个答案有帮助吗?
得分 0
添加一条评论
Charging my phone slow way
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eric Matibila 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 40
总计 3,654
