跳转到主内容
加入维修社区 - 创建账户
Kenmore 品牌 Kenmore 80 Series 洗衣机的维修指南。
Why will it not drain
Washing machine agitates and when it comes to their ring cycle will not drain
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi,
What is the model number of the washing machine?
Can you hear the drain pump operating at all on the rinse cycle?
由完成的
添加一条评论
2个答案
已选择的解决方案
Cause 1
Drain Pump
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
Cause Clogged Pump or Hose
Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Remove the hoses from the pump and check for any obstructions.
Cause 3
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not drain. To determine if the lid switch assembly is defective, use a multimeter to test each of the lid switches for continuity. If a lid switch does not have continuity, replace it.
这个答案有帮助吗?
得分 2
1条评论:
I had the same issue but in my case the solution was to replace the Washer Timer
由完成的
添加一条评论
Disconnect power at outlet. Backflush drain hose with house pressure. Check washtub for water flow while back flushing. Stop back flush. Check washtub for small foreign objects, or fur balls etc. reconnect drain hose to house drain. Turn on Machine and run pump and spin cycle.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Amy Boisvert-lane 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 53
总计 15,946
