跳转到主内容
A Toshiba laptop released September 2016, Identification Number C50D-A
Help! Toshiba C50D-A Missing Windows 7 Drivers
I've recently purchased a Satellite C50D-A-11Q and back-spec'd it to Windows 7 64 bit. Unfortunately; there are two drivers which, despite hours of searching, I cannot find. One is the Universal Serial Bus (USB) Controller and the other is the graphics driver. I've been in device manager and discovered that the Graphics Chipset is an AMD Radeon HD 7310 and the USB Controller is an AMD FCH USB XHCI Controller. However the correct drivers still elude me. Any suggestions gratefully received.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi ron.atkinson
Just curious on why you need to downgrade to windows 7?
most users should be moving on to windows 10 now.
you can try searching the device driver by using the hardware IDs
example
这个答案有帮助吗?
得分 0
1条评论:
I need to downgrade for my job. The software I use is Win 7 specific. I’ve looked in Hardware ID’s but everywhere I look the specific drivers can’t be found :-(
完成的
添加一条评论
添加你的答案
ron.atkinson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 17
总计 384
