跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
WiFi barely working after screen replacement
I recently replaced the screen on a original iPad Air. Everything seemed to go good, but now the WiFi works, but just very,very slow. The WiFi signal shows full strength. Could I have damaged the WiFi antennas by accident and why would it show full signal?
thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
The antenna wouldn’t slow the wifi, especially if you’re consistently getting a strong connection. Try resetting your modem or router.
这个答案有帮助吗?
得分 0
1条评论:
All other WiFi devices are working fine so it’s not the modem or router.
完成的
添加一条评论
Well turns out the iPad was restricted by a device called circle uaedmfor monitoring use.
Its our sons iPad. We reset that and it now works fine.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tim Stevens 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 132
