跳转到主内容
The Sony Xperia C is an Android phone which was released in July 2013. It features a 5.0-inch display with a ~220ppi density and an 8MP rear camera. The Xperia C can be identified by the model number C2305.
Why is Xpreia C4 shuting down itself while moving it.
Hello. Xpreia C4 is shuting down itself while moving it. Battery is full, but phone is shutdown itself  while i am moving the phone, while turning it in my hand or walking with it in my pocket... After shutting down, it isn't starting itself. I cannot start it with button also... I waited 1 week, then tried to start. it started. But while again i move the phone in my hand, it shuted down itself again... huh... what may be the problem. Anybody knows?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi Talha,
Your Sony Xperia C4 automatically shuting down does not necessarily mean that it has a problem. There are many possible causes for this phenomenon.
  1. The battery is defective - In cases where your telephone is old enough, it is feasible that it’s the battery. You can do a test with a secondary battery if you have. In the event that the problem persists, go to the store.
  2. The battery is improperly calibrated - To resolve this issue, you will need to let the Sony Xperia C4 totally unload. Once it is carried out take out and replace the battery in cases where feasible. Then connect it to charging and let it charge to the highest possible.
  3. Android is not up to date - If your telephone is out of date, it’s sometimes likely that your Xperia C4 will go out on its own. You ought to therefore examine that your phone is updated.
  4. Application - If your Xperia C4 always turns off when you use the same app, this means that the problem originates from there. All you have to accomplish is uninstall the application in cases where it’s.
I hope it will work.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tâlha Mesud 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 545
