跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Why would touch screen not work?
No broken parts that can be seen
Update
Thank you so very much....finally it works !!!!!
Voice over was the problem You guys are great :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
You are very welcome and this is what teamwork is all about....Bet pollytintop is enjoying a beautiful Royal Wedding (thanks for sharing)
完成的
yep.. bunting/party food/sweets/cakes.. we did the whole royal wedding thing. Not that I'm into the monarchy, but it's the feelgood factor.. everyone loves a good wedding!
完成的
Karen, thank you for accepting my answer and hope you keep enjoying your phone. Do not hesitate to visit ifixit for any further issues that may come up. Thanks to pollytintop for getting the ball rolling and for converting my comment.
完成的
添加一条评论
6个答案
已选择的解决方案
Karen, try to disable VoiceOver using the Accessibility menu in the Settings application. I think that is what draws the "box" around your icons. That would also mean that your digitizer works since it reacts to your touch.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
you may not have broken any glass but the touchscreen cable itself. try a hard reset..home and the power button together for 10 seconds, when the apple symbol appears release buttons and allow to reboot. if that doesn't work you could open the phone and check that cable no.2 is on properly. other than that it's a new digitiser you need
这个答案有帮助吗?
得分 2
8条评论:
I did replace the glass and the Lcd panel with digitiser (it was one piece) Any other sugestions?
When I touch the screen a white box will appear around the icon.....
完成的
So you already replaced the screen? I'm not sure what you mean about the square around the icon.. I would reopen the phone and clean connector 2 then make very sure it's on properly ( makes a click feel when on right) what happened to the phone to make you replace it?
完成的
pollytintop, I seem to remember there was a question on here about that a while back. I think it was something in the settings, disability something. Tried to find it but can't. Getting senile....
完成的
you're far from senile, I thought the touchscreen wasn't working... I guess if it makes little boxes it is! I'm senile, well .. mostly. :-)
完成的
well obviously two senile minds combined still get things accomplished...:-)
完成的
显示更多的3条评论
添加一条评论
i have connected the conevtore but still touchscreen isnt working
这个答案有帮助吗?
得分 1
添加一条评论
i have connected all three connectors back in the correct spots it lights up but will not touch activate
这个答案有帮助吗?
得分 0
1条评论:
try a hard reset. press and hold home and power button until the apple appears, then release buttons and allow to reboot.
完成的
添加一条评论
I am Really worried because the bottom of my iPhone 3 screen is not working Please help me
这个答案有帮助吗?
得分 0
1条评论:
same here ...top middle are working but not he bottom of screen of iphone3gs
完成的
添加一条评论
Hey guys plz help me i broke my glass and the touch screen go crazy idk what to do
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Karen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 8,192
