跳转到主内容
A collection of guides and support to help with washer repair.
3473 个问题 查看全部
Barrel/tub locked in place
I have a front-load Frigidaire Affinity washer #FAFW3801LW5 where the tub/barrel/drum will not turn even if you try and turn it with your hand. There’s just no give to it.
I recently spoke to the repair guy from the store that it was purchased from and, without looking at it, he believes that the issue is with the transmission. Stating that it was due to being moved without using moving bolts. He stated that it was fixable, but would cost $800 to fix.
But is this true, or are there other possible causes? And could I possibly fix it myself? As I hate to think that I’d have pay a lot of money I don’t have to get it fixed.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@shorai
I do not think your washer even has a transmission. It’s directly driven by the motor via a belt.
Consider to take a look at this by removing the cabinet etc. Remove the belt and see if you can turn the tub. this video should help you out. Yes, no matter what, you can most certainly repair this washer yourself.
这个答案有帮助吗?
得分 2
5条评论:
I can’t take the belt off. It’s too tight to slide off.
完成的
Never mind. I got it off.
完成的
@shorai can you rotate the drum by the pulley?
完成的
I managed to remove the belt without doing any damage. The motor wheel moves fine. Real smooth turn in either direction. The large pulley wheel is what’s locked up.
完成的
@shorai in that case it is most likely your tub bearing. Cheaper than a new transmission but a pain to get to it.
完成的
添加一条评论
If the stainless steel basket inside the washer will not turn, it could be bound up by a bad spin bearing. Pull the belt off and see if the motor pulley will turn okay without any resistance. With the belt still removed, try to spin the drive pulley on the back of the outer tub. If this pulley will not turn then the spin bearing is bad and the back half of the outer tub (that has the spin bearing pressed into it) will need to be replaced.
这个答案有帮助吗?
得分 0
3条评论:
If this is the case, how easy would it be for me to replace it?
完成的
Like giving birth
完成的
May is probably right, but it’s not a car. I mean you could easily take the whole thing apart. Automotive repair is such a hassle do to lack of accessibility and things are sometimes big and/or heavy.
完成的
添加一条评论
添加你的答案
Jason Scarce 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 14
总计 542
