跳转到主内容
A standard cordless compact DeWalt 18V drill with a high performance motor that delivers 380 watts. Equipped with easy to hold design that allows you to work in difficult spaces.
DeWalt DC970 brush replacment
Can the brushes in the DC970 be replaced or are they part of the motor?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
@countrylogic
Since the motor is the same as for the DeWalt DW959 it most likely uses a brush box. Take a look on here for that. post some more pictiures of your motor etc. when you get to the disassembly, that way we can see what you see. Use this guide 在已经存在的问题里加入图片 for that. DeWalt DC970 Motor Replacement
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
DeWalt DC970 Motor图片
指南
难度:
中等
10 minutes
这个答案有帮助吗?
得分 3
添加一条评论
I have the DW959, it has a sealed motor and you cannot replace the brushes. The motor part number is 615321-02SV. Most sites no longer sell it, it goes for about $60.
这个答案有帮助吗?
得分 3
3条评论:
I was able to obtain the motor for far less than the cost of a full replacement.
完成的
I just wanted to update my post, I found parts diagrams for the DW959 that show the brushes, however when I took my drill apart you cannot see the brushes and there is no spade connector to disconnect them. That end of the motor is entirely sealed. You may be able to disassemble the motor from the other end and remove the armature but that leaves the brushes 2 inches down in the motor casing. It doesn't look fixable to me.
完成的
I have a DW970 can't find brushes to purchase for my drill.
完成的
添加一条评论
添加你的答案
CountryLogic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 31
总计 3,587
