跳转到主内容
加入维修社区 - 创建账户
支持汽油动力和电动高尔夫球车,有时也指 Club Car Golf Cart 品牌命名为高尔夫球车或俱乐部车。
Forward/reverse lever are backwards
Hi gang, I have a 2001 Club Car DS 4 stroke gas engine. Problem is small but it irks me that I cant seem to find the solution. When the cart is in the forward position it goes backwards and vice versa..,when its in the reverse position it goes forward. A little help please...chances are this is a simple fix but I guess I’m having a brain fart and cant figure it out.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
That’s great looking into it now, I don’t see those studs but will explore a bit more.
Thanks a lot for your response, will keep you posted.
完成的
添加一条评论
2个答案
已选择的解决方案
Look at the motor. On one end of the motor (the side closest to the gearbox) the studs will be labeled S1 and S2 (for a Series cart) or F1 and F2 (for a sepex cart). Take those two cables off and swap them and your problem should be rectified
这个答案有帮助吗?
得分 2
6条评论:
Simple, brilliant answer.
完成的
I’m not sure what a sepex cart is...you do realize that I’m talking about a gas engine right?
完成的
sepex cart speed controller, https://www.buggiesunlimited.com/product...
完成的
No luck finding the two studs to swap over the cables, just dont see it. Sorry....thanks for trying though, appreciate it.
完成的
显示更多的1条评论
添加一条评论
The problem is someone has changed the motor. Earlier cc engines ran counter clock wise and the newer ones run clockwise hence your shifter works backwards
这个答案有帮助吗?
得分 1
2条评论:
So does this reverse the gearing as well? Reverse gears should be lower than forward gears correct?
完成的
This seems to be the correct answer as my cart is the same way.
完成的
添加一条评论
添加你的答案
Den Gauthier 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 53
总计 2,447
