跳转到主内容
HP Officejet Pro 8620 is a multifunction printer for copy, scan and duplex. This device can be identified by its model number: SNPRC-1401-02
Colours are printing with lines
Colours are printing with lines even after cleaning procedure as well warm water cleaning with syringe etc. Can you repair the head?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
Your printer software should have the option to clean the print head. Try that.
这个答案有帮助吗?
得分 0
1条评论:
that helps if the print head is still "treated as" ok.
usually only very little or parts of lines are not good.
完成的
添加一条评论
No luck in software or manual cleaning as stated.
这个答案有帮助吗?
得分 0
添加一条评论
No.
Usually you can’t fix the problem once the lines remain over more than 1-2 prints.
Problem is the print head of course.
The real question is WHEN does it happen and WHY.
In my case (Officejet Pro 8620) the lines started appearing immediately (!) after placing non-HP catridges to the printer when out of warranty. This is actually very unlogic from a technical point of view, as there still is original ink in the print head.
That’s why MANY SAY and so I do believe that the problem is “caused” programmatically.
So you would need to buy a new printer or at least print head.
PROBLEM. There is no real proof for what I claim or believe. Why?
HP can argue differently and we can’t look into the internal communication of the print head, main board, etc.
but I’m actually thinking of doing that, because it is possible with the right knowledge and someone should check against fraud.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Pieter Basson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 787
