跳转到主内容
Business-grade laptop released in 2009. Model Number: Latitude E5500.
Bios password unknow on my laptop
I would like to reinstall windows on my dell latitude e5550 but I do not know the bios password to change the boot drive sequence.
The Systemem Number: CQX1P72-6FF1
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
添加一条评论
3个答案
最有帮助的答案
On laptop if your bios password lost and you enter wrong password many times. then you get system disabled message with some number. now not down that number and now there are many python scripts are available on online which can regenerate your bios password from this system disabled number. download those scripts as per your laptop model. it is called dell keygen software and mostly in zip format.
You can reset bios password by jumper which is on your laptop mother board or desktop mother board.
On desktop computer if your remove battery from your motherboard and reinsert it after 1 minute your bios password removed or reset to default.
There are also master password for all laptop.
at booting time press f9 this will load default and you can reset bios password. To enter bios mostly f2 is used in dell and fp for default load.
这个答案有帮助吗?
得分 2
2条评论:
no jumper on motherboard
Remove battery doesn't reset bios password on my laptop
and generator doesn't give me a good password
完成的
Then contact local service provider. Without resetting passcode i dont think your can boot. Still try windows recovery dvd or make a try to boot with some usb harddisk or other bootable dvd.
完成的
添加一条评论
eu tentei com o gerador de senha mais esta dando em construção eu tenho 3 notbook dell 1 e e5500 so este que eu não estou conseguindo ta osso tem uma semana que estou tentando de tudo mais nem chega na terla do windows.
mais no teu caso e mais facil vou te passa um link e muito facil no teu casa o meu e mais complicado
https://www.techtudo.com.br/dicas-e-tuto...
这个答案有帮助吗?
得分 0
添加一条评论
you can disassemble your laptop and look for jumper around the Bios chip for reset it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dufour 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 48
总计 8,203
