跳转到主内容
加入维修社区 - 创建账户
Entry level business laptop introduced by Dell in 2014. Uses Intel Haswell (4th generation) processors.
Why laptop is overheating
my laptop is overheating
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Hi @jwamb ,
Here’s a link to the service manual for your laptop.
Scroll to the bottom of p.29 to view the necessary pre-requisite steps and then the procedures to remove the system fan so that you can clean it and the vents.
You may also use the opportunity when you have dis-assembled that laptop this far to remove/ replace the thermal paste that is covering the CPU, as the old application of paste has no doubt dried out and is not as effective. Be careful as you do this so as to not damage anything. As always with electronics be gentle. ;-)
这个答案有帮助吗?
得分 4
1条评论:
More like don't even think about opening it until you get the repaste done with how complicated it is on this generation of E5 series. Get it over with since the motherboard needs to come out.
My E6 series isn't as horrible (bottom cover only), but you need to remove the heatsink to unbolt the fan, which in turn requires new thermal paste anyway.
完成的
添加一条评论
Go for a cleaning job of your complete laptop it will helpful in dealing with your laptop overheating issue
这个答案有帮助吗?
得分 0
添加一条评论
It is overheating because your cpu fan is not makeing enought airflow to cool your components and you cant really fix it only if you replace the fan or make sure the wires witch power the fan are conected well and thermal paste is enought to cover the cpu and the gpu
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
georjo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 37
总计 2,480
