跳转到主内容
加入维修社区 - 创建账户
型号 A1419 / EMC 3070 / 2017 年中 / 3.4、3.5 或 3.8 GHz Core i5 或 4.2 GHz Core i7 Kaby Lake 处理器 (ID iMac18,3) / Retina 5K 显示屏。请参考较旧的 iMac Intel 27" Retina 5K 显示屏 (2014 年末及 2015 年) 指南,因为该系统的结构非常相似。
CPU Upgrade to 8th Gen Intel
Hello Guys!
Last year I bought a base model iMac 5K and it was working fine for me but my work has intensify and I would like to upgrade the CPU to an i7 and the HDD to and SSD .
My question is: Now that Apple lunched the Eight Gen CPU's in the new Macbook Pro. Can I opt for the 8700K(or any variant of it) instead of the 7700K?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
Sorry not an option in your system the rest of the systems logic would need to be swapped out as well (which is not practical) your system is based on Kaby Lake the new 8th gen is using Coffee Lake architecture while similar it’s not drop in compatible.
这个答案有帮助吗?
得分 2
添加一条评论
hi Alex Castro your imac only upgare to high cpu but only same life and socket
这个答案有帮助吗?
得分 0
添加一条评论
This is possible,It has been done on motherboards from third party vendors, apples logic is no different, What is needed is a patch for the bootloader, or a spoof in the efi and the compatibility fix added to it that was done with z170 motherboards.Whoever does it first will get a ton of rep.For now though if you can get a 7700k, you wont be disappointing, And I wouldn’t hold your breath on anyone in the mac community putting as much trial & error and time into this.(Just saw that its quite a few months old, didnt mean to revive the dead thread).I also swapped in a 7700k from an i5, tricky but rewarding.
这个答案有帮助吗?
得分 0
1条评论:
Yes its easy on a Windows PC, Mac's are a very different beast! Its just not that easy. Unless you've got the skills to dig deep into the firmware its just not possible!
完成的
添加一条评论
添加你的答案
Alex Castro 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 24
总计 3,800
