跳转到主内容
Is it possible to upgrade Memory (RAM) and Storage (SDD) later?
I am thinking of buying a MacBook Pro 13" TB 2018 with 8GB RAM and 512GB SDD, and after an of a bit of searching, I found upgrading them both i.e. 8GB to 16GB/32GB RAM & 512GB to 1TB/2TB SDD will be cheaper than going with purchasing high-end models of the Pro models. Is the new MacBook Pro customizable in the future with iFixit guides?
I had done the same with my current Mac Book Pro 13" Late 2011 with the help of iFixit guides and its working perfectly ever since, but will it be possible for the current newer generation MacBook Pro?
Regards,
AS
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 19
6条评论
Can i take my macbook pro 2018 to apple store to have the RAM upgraded or is that also not a possibility?
完成的
Unfortunately, they would not be able to upgrade the RAM at the Apple store.
完成的
Has anyone priced the upgraded motherboard? is that even worth doing??
完成的
@iopk - Sadly its not ;-{
完成的
I bought my wife a 2018 Macbook Pro last year - and a REALLY regret it. I didn't realize at the time that the RAM wasn't upgradable -and the $1500 computer is SO SLOW just one year later and I can't do anything about it.
I was already thinking about switching back to PC - I guess I have my reason now.
完成的
显示更多的1条评论
添加一条评论
9个答案
已选择的解决方案
Ammol,
Unfortunately in 2016 Apple decided that their Touch Bar based systems will no longer be able to be upgraded, as both the RAM and the SSD are soldered to the motherboard. The only way to upgrade those parts would involve replacing the entire motherboard.
In the teardown you can see the SSD highlighted in yellow, and the RAM highlighted in green.
I hope this helps,
Charlie B
这个答案有帮助吗?
得分 18
3条评论:
Charlie,
Thanks for your answer. Really helps, looks like I have pour down all my money on this piece of hardware. Does this also mean if and in case anyone damages any part of this machine, there is no such reparable option left other than to take it to apple service?
完成的
Anmol, While it would be possible for a third party repiar shop to fix the machine, it would probably be in your best interest to buy the extended apple warranty, since repairs through anyone will get extremely expensive.
完成的
this is a prime example of where the "Right to repair" law should be useful. Why is my ageing MacBook Air more upgradeable than a new one? only three components can prolong the life of any computer with several years. RAM, HDD, CPU. everything else is not really needed for 2-4 years more use.
完成的
添加一条评论
Hi @anmols ,
MacBook Pros have changed drastically since your 2011 edition. Everything is soldered onto the motherboard in the MacBook Pro 2018. The RAM and “SSD” are now merely memory chips on a motherboard. Nothing is user-replaceable. Take a look at our teardown for full details.
这个答案有帮助吗?
得分 8
1条评论:
Hi @arthurshi,
完成的
添加一条评论
You have to begin thinking or wondering… Why do I patronize Apple? I can’t upgrade anything. I’m locked into their ecosystem. They are constantly taking things away that I value (and I’m the Customer!) They tell me what I need, when to eat, and what to wear…..
Is it me or is does this seem like an abusive relationship… LoL!
这个答案有帮助吗?
得分 5
2条评论:
Yeah, I think the same way. I just bought a Macbook PRO second-hand and now realized why it was sold. It was my first Apple Computer and probably the last one.
完成的
It's a part of the brainwashing of society. For such an abusive company, people certainly put them on a pedestal. Very odd. Most PC laptops give you all the flexibility you need, and if the system has irreparable issues, you take out your hard drive with your data and happily go on your way.
完成的
添加一条评论
The 2016 & 2017 Function Key models SSD can be upgraded with this original Apple SSD
https://beetstech.com/product/solid-stat...
这个答案有帮助吗?
得分 1
1条评论:
Only the 2016/17, no more since 2018 generation. Always buy fully equipped, that's easiest. Hope your employer pays ...
完成的
添加一条评论
I’ve been pegging out my 2018 MBP RAM 24/7 due to doing JavaScript development, so I am running VS Code, webpack, and four instances of Chrome for various reasons. Once I get around 20 tabs open, the 16GB RAM is pegged out, and then every time I refresh a page, it takes like 5-10 sec because I have browser caching disabled.
This is of course horrific because I am developing, so I am saving JavaScript files every 5-30 sec and reloading the page. It takes sometimes like 30-45 sec to refresh the page, make a one character change in a file, save, and reload the page again. It makes me feel like I’m back in the year 1999 with 24 megs of RAM.
This laptop is only a year old, and if I had known it can’t even handle normal software engineering loads, I would have forced my company to buy the 32GB version. Lately I was thinking about buying one of the new Apple towers with 28 cores and capability of 1.5TB RAM. They’re $5k which is expensive but that kind of power would be viable for the next decade.
Now I’m !#^&@@ though that I can’t even swap my 16GB chip out for a 32GB. I’m going to build my own computer; I’m gonna make a hackintosh and also just not use OSX if they ever figure out a way to prevent it from loading on my machine. And to be clear, I was going to just stick with the Apple tower because it makes it easy to run OSX fully legal, but now I’m going to take a different path, one that involves punishing Apple for crippling my laptop’s viability as a docked mobile workstation.
The sociopathic intent of Apple is clear. I can’t support a company like that. I’ll give them the right to repair trust, but it will take major effort on their part. In the meantime, I’ll keep pulsing anti-Apple sentiments out on every information medium.
这个答案有帮助吗?
得分 1
5条评论:
I'm in the same situation, I just jumped in the Apple world in a $2k machine and starting to be sorry. My "PRO" machine can't be used for my PROfession and neither upgraded. Probably I'll go back to thick laptops with Windows or Linux.
完成的
yeah this sucks, looks like I will get a mac pro, like suggested above, and maybe keep my 2011 mbp.. i7 32gb RAM and 1tb on dual ssds (removed the disk drive for a 2nd ssd) fantastic machine until apple stopped updates..
完成的
I'm waiting for the new Mac Pro 2019 to come down in price, it's fully upgradable.
完成的
Stop supporting Apple, and change your last name! Or change your first name to something like "Dontsupport". lol
完成的
Totally agree with you Adam. Apple's no repair policy sucks...what about sustainability instead of consumer control. Let me see, what can MicroSoft do for me!
完成的
添加一条评论
Reading this because wifey want to buy a new mac. I recommended her going for the 2018 model and use the money saved to buy a memory upgrade. This will result in a better machine then buying the 2019 model.
But hey apple forces you to buy their extremely expensive memory upgrades. They remove everything where pro systems stand for. Flexibility to adjust your machine to your needs! Unfortunatly she doesnt want to work with windows so we will buy this overpriced piece of $@$*.
这个答案有帮助吗?
得分 1
添加一条评论
This comment is misleading as the 2015, 2016 and 2017 MacBook Pros can be upgraded in terms of SSD storage, but not RAM.
Update (08/21/2020)
I give up!!!
这个答案有帮助吗?
得分 1
3条评论:
@Kevin Gill - How so?
The MacBook Pro Touch Bar series (13" & 15" as well as the newer 16") are not upgradable!
Are you thinking about the Function Key models? Only the SSD is serviceable. Its a custom Apple drive so your choices are limited.
完成的
Only the 2018 MacBook Pro models are non-upgradeable full stop. Previous non Touch Bar models can have their SSD replaced with a higher capacity. Pretty easy to do. I'm typing on a 2017 model that now has a 256gb SSD
完成的
@Kevin Gill - Not MacBook Pro laptops! You are thinking iMac desktops a very different beast.
Did you even review the iFixit teardown's? Here's a sampling of the 13" models, the 15" models are configured in the same way.
MacBook Pro 13" Touch Bar 2016 Teardown
2018 款 13 英寸带触控条的 MacBook Pro 拆解
2019款13英寸双雷雳接口MacBook Pro拆解
完成的
添加一条评论
Hello, in the A1708 (pro) models without touch bar if the SSD storage can be upgraded (you only need to buy an adapter and a m2 SSD)
For the ram memory requires more work since it is soldered to the board and requires desoldering and soldering the new integrated
Excuse me if my English is not good, I am a Spanish speaker
这个答案有帮助吗?
得分 0
添加一条评论
Hey, you don’t need to apologize for language skills, the message was perfectly clear.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anmol S 将永远感激不已
浏览统计数据:
过去 24 小时: 17
过去 7 天: 90
过去 30 天: 462
总计 172,079
