跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Why Is My Phone Stuck on Boot Loop After Liquid Damage?
Hi, first of all I would like to say I'm not looking for simple answers, i.e - hard reset, disconnect / reconnect battery. I would like to know if anyone out there, all be a technical genius could answer my question and give me some pointers. Now I'm no professional at phone repairs but I've done a fair few to understand the basics. I've never done any IC soldering / repair nor can I due to lack of equipment.
Basically, my question is this: Why is my iPhone 6 stuck on a boot loop when plugged into mains power but will not turn on independently via usb to pc or by it's own battery (new battery). The phone I believe has suffered water damage and after inspecting the pcb I noticed a scorch mark on the lower part of the board's shield. I have no idea what IC's to look at or what areas to look at first.
I've noticed that some of those IC's have suffered some damage and I believe maybe some of the board's ceramic caps are missing / damaged. I only have a soldering iron and a conventional multimeter, so any starting point would be good.
Any information regarding that would be great. Thanks.
https://ibb.co/heom3d
https://ibb.co/dPM63d
https://ibb.co/gmPFwy
https://ibb.co/fXWvwy
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
ok brandon your phone can bootloop with shorted components but finding the actual component can be difficult if you don't have a dc power supply. i suggest you take a look at the capacitor to the left of the wifi chip even if you knock it of the phone will still work
这个答案有帮助吗?
得分 2
2条评论:
Thanks. Do you by any chance know where I can find a diagram / schematic of the iPhone 6 logic board? I don't know where what IC's sit where.
完成的
possibly a zxw file type from gsmforum
完成的
添加一条评论
添加你的答案
Brandon Frost 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 95
