跳转到主内容
加入维修社区 - 创建账户
Linksys EA6900 智能 Wi-Fi 双频路由器是一款四端口无线路由器,设备背面配有三根天线。该设备还具有两个用于存储的 USB 端口(3.0 和 2.0)。
Internet connection not working
My router is working fine but it cant get an internet connection. I've reset it multiple times
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Hi @dgold44 ,
Has it worked OK before?
Can you connect to the internet when you are directly connected to the modem?
由完成的 分享
Yes it works perfectly fine then sometimes at night it just completely stops working.
由完成的 分享
Hi @dgold44 ,
Just to clarify, it is the router that loses internet connection not the modem, is this correct?
If it is the router is it still showing as connected to your computer, even though there is no internet connection?
Have you tried a different WiFi channel (change in router) just to see if it behaves the same?
Have you checked that your model router has the latest firmware installed?
由完成的 分享
添加一条评论
1个答案
Hi Dawson,
This can be multiple things but you can try these following things:
-Make sure that the cable from the modem to the router is connected
-Reset the modem
-Try a diffrent ethernet cable from the modem to the router
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dawson Goldsberry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 19
过去 30 天: 31
总计 1,037
