跳转到主内容
加入维修社区 - 创建账户
Chevrolet C/K 正式名称为 Chevrolet C/K,是通用汽车生产并以 Chevrolet 和 GMC 品牌销售的系列卡车。C/K 系列包括皮卡、中型卡车和重型卡车。
key switch replace or repair
how to replace key swicth in the ingnition
回答此问题 我也有这个问题
这是一个好问题吗?
得分 11
添加一条评论
4个答案
最有帮助的答案
Open the hood to access the battery. Disconnect the negative cable to isolate the electrical power.
2
Open the driver's side door for more room to remove the ignition switch. The switch is located on the steering column.
3
Unscrew the shroud around the steering column with a Phillips head screwdriver. Pull the shroud out from around the steering column once it is loosened.
4
Locate the switch by the ignition lock. The switch will be screwed into the column.
5
Pull the wires out of the back of the switch by hand. The wiring harness will have locking tabs that must be pulled out to separate it from the switch.
6
Unscrew the switch from the column with the Phillips head screwdriver. Pull the switch out of the column.
7
Place the new switch where the old one was located. Screw the switch to the column with the Phillips head screwdriver.
8
Push the wiring harness into the back of the switch. Push in the wiring harness until it locks into place.
9
Fasten the shroud back around the steering column. Tighten the screws with the Phillips head screwdriver.
10
Connect the negative cable on the battery with a line wrench. Ensure both cables on the battery are tight.
11
Start the truck to ensure the ignition switch is functioning correctly.
这个答案有帮助吗?
得分 4
1条评论:
I have a 1989 chevy pick up..no screws below .just 1 bolt holding wheel & the locking thing..
由完成的 分享
添加一条评论
the rod from the key to the switch is offset that is what i need to fix
这个答案有帮助吗?
得分 0
添加一条评论
Hi,mine is just got 274000 miles on it
这个答案有帮助吗?
得分 0
添加一条评论
Ignition switch change
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ron hughes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 41
总计 35,794
