I have a green tint on all the faces on the tv
When I put the tv on this morning there was a green tint on all the faces and everything else, it was fine last night.
I have tried plugging the TV to another power source like the wall (apparently that worked well for others) and also another surge protector but it didn't work unfortunately
The model is Toshiba LCD 37WL68P.
Here we can see an unusual color in the sky
Here are some stains on the right of the ground which shouldn't be like this, it gets worse usually
I haven't been able to get a picture of the stain on faces but it's like a green mask that follows the edges of the face.
The picture is perfectly fine on certain shots which makes me think it's only a certain color or something but I'm not the expert :) Thanks a lot for your help
5条评论
To fix this problem of the green squiggly lines around all of the faces and totally shaded in green upon all the cheeks. I just unplgged the HDMI Cable from the back if the television itself, gave it 3 swift forcefull blows of air from my mouth, plugged it back it real tight.Then next, I unplugger the same connecting HDMI cable stemming from the TV to the rear of the cable TV Receiver, repeated step 1, blew on the end of that cable as well, plug it back really tight again. Do the unplugging and blowing while the TV is off, takes about 5 minutes total, then returned back to my seat, turned the power back on and WHAAALA, ITS ALL REPAIRED! FULL NORMAL COLOR SHADING RETURNED! Good Luck, everyone! Save Yourselves some money $$$$$
由 Gloria Raines 完成的
I have the same Green-face problem, Toshiba CT-90275. It seems like a tint issue, “but”, I also have a feeling it is dust inside the TV issue. Need to de-dust it.
I will buy a dusting-aerosol type bottle to blow air into the back vents, i hope it works. I'll reply later this week with results if worked or
由 ojib wayne 完成的
Hey, ojib wayne. I have the same model of Toshiba and the colors just got all distorted. The tv could just be broken. But did your dusting fix your screen?
由 Olema 完成的
have the same problem on my new jvc.
由 Paul Bladesman 完成的
I'm having trouble with my new jvc also
由 Garry Harrison 完成的
