跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
Battery not being detected
My Macbook was running fine and then I put windows 10 on it and i didn't want it so i went back to mac and then It started not to get detected anymore.. I plug it in and turn it on and then remove the power cable and it stays on but it wont start without the power cable and it will have an X where the battery is?...... how do I fix this? do I have to download something or what? PLEASE HELP
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Have you tried removing the battery and putting it back in? Sometimes an smc reset will fix this issue, otherwise you may need a battery replacement.
https://support.apple.com/en-us/HT201295
https://support.apple.com/kb/PH25542?vie...
[无效指南链接]
这个答案有帮助吗?
得分 1
1条评论:
I've done it many times and I have 3 batterys and nothing works... seeing that if I unplug the power cable and it stays on i believe its not the battery or the pc in any way I think its just something thats not allowing it to be detected..
完成的
添加一条评论
What does your onboard battery tester tell you about the charge status of each battery are all the LEDs lit?
I would download this gem of an app: CoconutBattery. It will give you a deeper view of your batteries as well as your systems charging logic and even the power adapter.
Here’s a useful reference on battery life time (cycles): '''Determine battery cycle count for Mac notebooks''' As you can see Your MacBook’s battery life is quite low (300~500 cycles) you may need a new battery.
Lastly, you may want to review this useful Apple T/N: '''About Mac notebook batteries.'''
这个答案有帮助吗?
得分 1
2条评论:
I have 2 other and its the same thing and all the LEDS are lit
完成的
What does Coconut tell you on there cycles?
完成的
添加一条评论
@pig reinstall your OS if this error started with your installation of Windows. It is easily possible that you have corrupted the software. Of course you also want to try a SMC/PRAM reset to see if that changes anything.
这个答案有帮助吗?
得分 1
3条评论:
I've done this a few times already and nothing...
完成的
@pig so you formatted your drive cleaned it up and reinstalled your OS and no change?
完成的
Yes no change.. I just think its someone I need to install or something.. because if I plug it in and turn it on I can unplug it and it stays on but once it turns off I need the power cable again... I believe its not the battery seeing i have 3 and it does the same thing and not the PC because if it was it wouldn't keep it on with the battery once unplugged
完成的
添加一条评论
添加你的答案
Dwight 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 114
