跳转到主内容
Repair guides and support for motorcycles manufactured by Kawasaki.
22 个问题 查看全部
Stator over heating connecting plugin
1980 Kz750 ltd H1. Does the stator produce different voltages from each of the 3 yellow wires? Can the wires be plugged together wrong? The secondary plugin (white snap together) is over heating leading me to believe a backfeed is in progress. Wiring diagram is not much help, it shows close wire connecting to close side of rectifier, is this right? How are you supposed to determine which wire is the close side?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@kawrider this sounds more like a bad regulator (failed diode or thyristor) than a stator issue. The voltage supplied by your alternator is continuous and even across so there are no different voltages nor is there any feedback to the stator. It's all in the regulator. I attached the part about the alternator and regulator from a manual so you can check it out. KZ750-charging.pdf
这个答案有帮助吗?
得分 1
2条评论:
changed rectifier/regulator and stator none of it helped, possibly a short in secondary harness.
Thanks for the input though, at least I can get some realistic answers here.
完成的
@kawrider sorry to hear that. Besides the stator have you checked the alternators output? You should get ~50V AC from yellow to yellow (you need to measure all three yellow wires).
完成的
添加一条评论
添加你的答案
James Guyer 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 6
过去 30 天: 8
总计 81
