Boot device not found
At start screen boot device not found is showing. I am unable to get into bios and uefi is not showing component testing what should I try next?
Hi flee865
had you tried this?
what is your current OS?
Turn off the computer.
Hold down the windows key + b and power on the laptop without letting go.
Here's the magic: while holding down windows key + b, then press F2.
The laptop will enter BIOS recovery mode, and you should be all set from there.
Reference:
https://h30434.www3.hp.com/t5/Notebook-B...
When you had successfully entered the UEFI / BIOS, check if your hard disk is detected,
consider running diagnostics on the HDD, also to ensure if the bios boot setting is correctly configured, e.g. secure boot, uefi.
else if it is not detected, try reseating the HDD and repeat the process.
or else get another HDD to test, if it is detected, consider getting a replacement . SSD is recommended.
这个答案有帮助吗?
It says bios recovery not found I only tried the first step
Hi flee865, had you tried with other keys? e.g.
Esc,F9,F10,F1,F2 etc
On the computer and press F10 fast.
you might also need to check in hp for updated bios for update or recovery.
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 18
总计 1,544
