跳转到主内容
A simple, straight to the point, cell phone released by Nokia in 2005.
Insert sim card solution?
Why my Nokia 1600 keep saying insert sim card when I had put sim card?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi @arjunan ,
Try swapping your SIM card with another network compatible,known working SIM card from another phone and see if your card works in the other phone and the other SIM card works in your phone.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Sim cards are very precise instruments if you did not put it in properly it could be giving you this message. Otherwise it is probably a problem on the inside. open it up and check the cellular antenna wires. You can see if a wire is out of place, otherwise replace that entire piece.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Arjunandrey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 1,458
