跳转到主内容
The HP Envy x360 m6-aq103d has touchscreen and 360° capability, which makes it a 2-in-1 for those that want a laptop and tablet in one device. Model number: W2K45UA.
Replacement part for my HP Envy
I would like to find out if possible where can I get a replacement part for my HP envy 360 m6 earphone Jack thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi @geomichi ,
What is the full model number of your laptop?
完成的
It's the HP Envy 360 m6-ar004dx
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @geomichi ,
Here is a link to the service manual for your laptop , taken from this HP webpage.
Scroll to p.38 to view the necessary pre-requisite steps and then the procedure to remove the connector board. Also on p.38 you'll find the spare part number for the board 856792-001. (and also the cable part number 856801-001 if it is necessary).
But on p.16 it shows that the connector board part number (#9) is 856808-001. Bit confusing.
Search online using the part number only in the search box of your browser, to find suppliers of the replacement board.
Both board part numbers seem to point to the same board when searching online.
Check what number is stamped on the board in your laptop, if any.
Hopefully this is of some help.
这个答案有帮助吗?
得分 2
1条评论:
Thank you very much it's appreciated I'll search and see if it can slove my problem again thanks.
完成的
添加一条评论
添加你的答案
Nicholas22 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 566
