跳转到主内容
From the Inspiron series 15 model 5558 released in 2015 by Dell. A mid-level laptop with a 15.6-inch display and fifth generation Intel processor.
18 个问题 查看全部
Can we use USB for Garphics card storage Improvment?
Can we use external USB drive to increase graphic card memory? to get faster experience, I'm Interior Designer and generally using for Interior view rendering with vray Can I speedup with my USB drive to increase storage of graphics?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi,
No.
Here's how ReadyBoost works to help system memory not video memory.
Check how much system memory you can assign to video memory. (Graphics properties > Advanced Settings > Shared system Memory)
这个答案有帮助吗?
得分 2
添加一条评论
It is not likely that you can increase your Graphics memory. However, you could increase your system memory, which would result in better overall performance. For example, increasing your system memory would speed things up when you regenerate a drawing. But in order to achieve this speed improvement, you will need to use actual memory, not a USB drive which is acting like memory.
If you currently don't have enough memory, you will sometimes have bottlenecks ("traffic jams"), slowing everything down. In this case, anything which will alleviate the bottleneck will help. This is the one case where using a USB drive as memory will speed up your system. But since USB is a lot slower than actual memory, you would be a lot better off by adding actual memory to your system rather than by using a USB drive as memory.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sandeep Patel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 7
总计 207
