Why is my laptop display split into 3 sections?
My laptop screen split into 3 sections, the right section appears to the left and the left appears to the right, the center remains in the center but keyed out!
This is a picture taken from my laptop
@ejdr it will help if you let us know the exact model of your laptop. Also, even so your description is good, it might help if you post some images of t\what your screen shows. Use this guide for that. 在已经存在的问题里加入图片 It will allow us to see what you see. Connect an external monitor to your laptop and see if that displays right. If it does then you probably have an issue with the driver board of your panel. This would require a display replacement (y first suspicion). If it doesn't display properly it could be a GPU issue (motherboard) or a driver issue. Depending on your OS you may consider a driver update for your video card (GPU)
这个答案有帮助吗?
When I connect it to a monitor it shows good but in my laptop it splits in 3 sections
Okay, sounds like a bad LCD. You will see there there is a circuit board that is directly connected to your LCD and it is really not replaceable. It is on that board that you have a component failure.
@oldturkey03 what is the possible solution for this?
can I fix it?
Only repair for that is the replacement of the display
过去的24小时: 0
过去的7天: 17
过去的30天: 96
总计 5,524
Hi @ejdr ,
Try starting the laptop in safe mode and see if the problem is still there.
If it works OK then perhaps it is a driver issue.
Stupid thought but can you "drag" (click and hold while moving) the right side of the screen back to its' proper position on the left?
由 jayeff 完成的
No it cant move
由 Elvin 完成的
But sometimes it goes back to normal. Is it possible that its the display assembly?
由 Elvin 完成的
Var der nogen løsning? for jeg har samme problem.
由 Ib P. Jensen 完成的
Hi.My laptop is doing the same too,It's splitting into four sections with a poor quality and a black line crossed between the 2 sides of right and 2 sides of left
由 Takudzwa George 完成的
显示更多的3条评论
