简介
这是个“快速且(Dirty)”指南来教您如何在已经存在的问题中加入图片
鼠标移动到问题界面右上角的选项处,然后显示菜单。
点击编辑来打开编辑发布页面
在添加图像之前,将光标置于要添加图像的文本中的位置。 我们建议把它放在问题的最后。
点击图片标志来打开媒体管理界面
点击添加媒体从计算机中选择要上传的文件。
插入图像后,滚动到页面底部并点击预览编辑。
预览会自动插入到您要查看的字段下面。
如果一切正常,请点击提交编辑。 如果不是,请向上滚动并根据需要调整您的问题。
Ugh, I'm so frustrated with iFixit's image uploading! Seriously, it feels like dodging meteors in the Chrome Dinosaur Game just to get a simple picture loaded. Was it always this convoluted? Makes me want to give up and just describe everything with words. Please tell me I'm not the only one struggling! Maybe there's a hidden trick?
Tarkington - 回复
插入图片一定要是800乘以600的大小,不然的话媒体管理将会报错。 这看起来很复杂,事实上是很直截了当的。
105等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
51指南评论
Were would i be able to get these images shown on the repair o0f tv`s ,is there a link,Thankyou in advance
@moggy01 what images are you referring to?
&&^& Uuuuuuuu
Oldturkey03, I have a Sonicare Complete 4717. I figured it out. But now I would like to know if I can use an alternative to Soldering, since I don't have one.
Check your original question on Answers....
[|wanna know why my TV is like] this.
First I havn’t taken the back off tv. However I knowest that when I put power to the tv to on the screen lit up with channel no for three seconds then blanks out does this information tell you anything possable John
@oldturkey03 You may want to have a look at what someone tried to do to step 5 of your guide. It somewhat baffles me.
I added an image almost a week ago and I don’t know if you received it or not. Can you let me know?
Reatha
Oi m8 how u bin waiting 4 a reply..
Help tv &&^&.. flashing red light.. turn on goes green but screen flickers.. then goes bk to flashing red blank screen??
gefeltaFISH
Can
G Rodd -
TV light stays on and it flickers can't shut it off even when I unplug the tv
turukavita - 回复
My samsung tv wont turn on the red light keeps flashing and there is no picture what do I
turukavita - 回复
The main board is probably bad
Sotry you feel that way mayer!
Noe Viesca - 回复
Hi, can someone help me please?
my Panasonic TV is not turning on. Showing a red flashing light. I have used all the instructions given on here and still no luck. Not a great time as we are all at home with one TV that doesn’t work!!
Hello gud morning, pls my Samsung TV 32 inches is not coming on red is just blinking, this is the model code (UA32H4100ARXSW, thanks.
I absolutely cannot get media manager to work. I’ve tried it in Safari 14.0.2 and Google Chrome. My iOS is 10.14.6. I can get the images into Media Manager but can’t get them to upload. I’ve followed the directions, clicked the image and nothing happens. Why is there an Add Media button if it’s useless? Out of the 30 times I’ve tried to upload the images, one uploaded and I was so excited I tried uploading another one and no go. I’m not able to exit MM after I’ve cleared all images. I cannot get back to my thread, I have to press the back button and that messes up where I was before trying to insert the image. I need to get the screen shots into my thread so the people trying to help can see what I see. Any ideas as to why I’m having these problems?
LG tv 65incher load bang , no obvious damage on either side of all circuit boards but tv is dead as if no supply voltage no lights nothing no sound just remains
guys, nothing is working, plez help me. thnx to anyone who reponds to this comment
I am here just because after face most of difficult steps vbucks generator finally I found my solution.
Model number is UN58H5202AF
Type No. UN58H5202
Version No. IS01
Sin: 036x3czhb00139l
It's blinks 5 times and nothing. Has no remote. What should I do
My tv flickers too then turn black and I know my backlight is the problem, but I'm not sure whether or not to fix the power board or the LCD strips. I also can't tell if they are damaged or not.
Also I cant seem to send pictures too
Thanks to contributors. Get Anniversary Decoration at Home Done perfectly.
hi, I have a hisense tv when I pless on pictures comes on just few seconds it goes blank but I can still here the voice. any help I will appreciate it?
So, was the problem fixed??? My Hitachi just went out today and I’m a little skeptical on going through all that or just buying a new TV.
wileygator - 回复
what Hitachi? what problem?
Hi, I have the same problem, with the Pioneer SP-SB23W, also known as the "Andrew Jones Edition", the system starts normally but, don't work correctable, just make little a sound like plum, and don't make anything after that. Sometimes stars fine bunt the most of the time don't work fine. Thanks.
I refuse to believe it, but I have to accept the fact that iFixit has made picture uploading more complicated than it used to be happy wheels game. What a pathetic group of idiots.
Leon Watts - 回复
It's hard for me to believe, but I have to accept the fact that iFixit has made picture uploading more complicated than it used to be happy wheels game. What a pathetic group of idiots.
Leon Watts - 回复
I was working on it and the guy from theballoonwala helped me with this guide. thank yu
Tarkington - 回复
