跳转到主内容
加入维修社区 - 创建账户
1986 年至今的 Harley-Davidson Sportster 摩托车。
E carb break up...
1987 Sportster 883. 1200 heads, s&s E carb, upgraded s&s air cleaner. Was breaking up entire range. Main jet from .070 to .074. Pilot jet from .028 to .030. Much improved but still slight break up mid range. Should i increase either jet, both, or maybe air bleed. Break up is in carb like a fuel starve.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@firstharley if you are only breaking up at between 2000-3500 but not above and not at idle leave the pilot alone and concentrate on the main but before you do look for vacuum leaks . Check the oil for fuel you can get the same miss with a rich burn . Whats your plugs telling you ? Do you smell fuel at all?
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Lee 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 15
总计 328
