跳转到主内容
加入维修社区 - 创建账户
该机型使用非 Unibody 一体成型机身,使用 Core Duo 及 Core 2 Duo 处理器。
How to check fans
over heating which causes left side of keyboard to not work. How do I check whether the fans are working?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
8条评论
thank you, Skippy, downloaded and fans are working, but where do you find the SMC control
完成的
MY GPU diode is 144 degrees, seems pretty hot and heat sink is 114, is there a place I can find what temps should be?
完成的
144 on the GPU diode is pretty normal... on my imac (2.66GHz C2D, Radeon HD2600) the GPU diode is 135 with an ambient 72... Just depends on the type of computer and the ambient air temp...
SMCfancontrol can be downloaded here -http://www.macupdate.com/app/mac/23049/s...
On my imac, i run the fans at 2800rpms across all 3 which keeps the idle/web browing temps under 100 and my gaming temps (l4d2, portal, killing floor) under 130
完成的
Sorry I didn't link to SMCfancontrol in my other post...
完成的
Thank you again. I did download SMC fan control but it doesn't work. I get the icon but nothing happens when I hit it. So I cannot control the fan. Any tps?
完成的
显示更多的3条评论
添加一条评论
3个答案
已选择的解决方案
I use iStat pro to check my fans. SMCfancontrol lets you adjust the speeds manually yourself
http://www.islayer.com/apps/istatpro/
这个答案有帮助吗?
得分 2
2条评论:
nice app. And it's free. +1
完成的
I like SMC because you can set fan speed "Profiles" which u can quickly adjust from the menu bar. +1
完成的
添加一条评论
I've had to replace the fans on three of the 17" machines. All started with the left fan going out first. Failure included a very loud screeching noise at the end. On the first one I just replaced the left fan, then two weeks later the right fan failed. On the next two I torn the machines down to the heat sink, cleaned the vents which were about 70% blocked, replaced the thermal paste on the heat sink. That solved the problems and the machines have not been back in. Here's how to replace the left fan: MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left Fan Replacement Here's the right fan:MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Fan Replacement
Here's how to get to the heat sink: MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Heat Sink Replacement
Here's a general guide on how to replace the thermal paste. I use Arctic Silver Thermal Paste: 如何涂散热膏
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Fan图片
指南
难度:
中等
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left Fan图片
指南
难度:
困难
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Heat Sink图片
指南
难度:
困难
Electronics Skills图片
指南
如何涂散热膏
难度:
中等
5 - 20 minutes
这个答案有帮助吗?
得分 1
添加一条评论
Your Majesty,
Just now saw your note. Thank you. I downloaded SMC control again and found the controls. I have set the temp at 3000 as suggested though the fans are audible they are not distracting. I hope this doesn't cause earlier wear and tear on the fans.
Again thank you and problem solved.
这个答案有帮助吗?
得分 0
1条评论:
Running them will cause them to where out a bit faster simply because they're spinning faster, but it's nothing to worry about really.
完成的
添加一条评论
添加你的答案
Raul 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 17
总计 10,545
