跳转到主内容
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Fan Replacement
你所需要的
  1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
  2. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Fan Replacement, RAM Shield: 步骤 2 中的图像 1,1
    • Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
  3. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Fan Replacement: 步骤 3 中的图像 1,1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Fan Replacement, Upper Case: 步骤 4 中的图像 1,1
    • Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
  5. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Fan Replacement: 步骤 5 中的图像 1,1
    • Remove the following six screws:
    • Two 14.5 mm T6 Torx screws on either side of the RAM slot.
    • Four 3.4 mm Phillips screws along the hinge.
  6. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Fan Replacement: 步骤 6 中的图像 1,1
    • Remove the four 3.4 mm Phillips screws on the port side of the computer.
  7. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Fan Replacement: 步骤 7 中的图像 1,1
    • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
  8. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Fan Replacement: 步骤 8 中的图像 1,1
    • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
  9. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Fan Replacement: 步骤 9 中的图像 1,1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  10. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Fan Replacement: 步骤 10 中的图像 1,1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board.
    • Remove the upper case.
  11. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Fan Replacement, Right Fan: 步骤 11 中的图像 1,2 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Fan Replacement, Right Fan: 步骤 11 中的图像 2,2
    • Disconnect the display data cable and right fan cable from the logic board.
    • If you have a MacBook Pro 17" Model A1229 or A1212, the connectors have different compositions and are highlighted in the second picture.
    • For models A1229 and/or A1212, carefully wedge the flat end of a spudger underneath the right fan cable to pry it up off its socket. Failure to do so may result in the whole socket coming off the motherboard instead of just the cable.
  12. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Fan Replacement: 步骤 12 中的图像 1,1
    • Remove the three silver T6 Torx screws securing the right fan.
  13. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Fan Replacement: 步骤 13 中的图像 1,1
    • Lift the right fan and its metal bracket out of the logic board.
结论
82等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了636篇指南
3条评论
Easy job, super guide, vacuum the the cooling grill when fan is out, changed both fans, because one fan got very loud, it's a 2007 Mac book Pro, so no reason not to change both, went from 6000 rpm to 3000 rpm, nice, big thanx to ifixit…
jjhomann - 回复
-thanks for the tips and prompt delivery to Canada from ifixit.com...took me 5 minutes. Use a tweezer with one hand as I did in the video ( http://goo.gl/3EZ5N5)
-recommend placing he mac on a soft towel to prevent scratches.
-Use precision screwdrivers (http://goo.gl/qRK4IF)
-use a compressed air canister to clean surrounding areas
Works like a charm now...
SRIBULUSU - 回复
do you know if is it needed to change the black tape, how do i replace it?
where can you find the same tape?
i have done that but the fan is no more sticking to anything.. help!
jacopo - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 39
总计 44,740
