跳转到主内容
The Acer Aspire One model D225E is a 10.1-inch netbook that features an ultra-thin and lightweight design with a powerful battery making it ideal for everyday computing on the go. Also known as Acer Aspire One D255E-13639.
I shorted out my usb port
tyler.norton82 less than a minute ago
I shorted out my laptop, I was trying to plug my headphones in the dark and it went into the usb port. When I went to turn it on, the fan starts the power light turns on for about 5 seconds, but the screen doesn't turn on. Then it shuts off and tries to start again, over and over. U my lap top is a Acer aspire e15 e5-511-c0pc. I'm not to familiar with laptops, I have once taken it apart to replace the hard drive. Can I take out the memory and hopefully fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Unplug remove battery hold down power button for 30 seconds grab a door knob to make sure to discharge any static from your body tske paper clio and look i side usb and strighten all the pins. That should work if n o t replace usb port its shorted out
这个答案有帮助吗?
得分 1
1条评论:
@retlaw132002 thank you for your solution comment.I really appciate
完成的
添加一条评论
添加你的答案
Tyler Norton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 449
