跳转到主内容
加入维修社区 - 创建账户
A series of 40 inch LCD HDTVs by Sony.
Is the display unit broken
When I switch on I have a series of thin white horizontal lines over the whole screen.
They are there when playing tv programms and also when playing DVDs.
Is this a display unit problem and if so is it replaceable?
Thank you
Rick
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
@rjpharoah horizontal lines are most commonly caused by a failed panel. This is not repairable but would require a new panel. To be sure of this we would need a complete model number and would need to see those lines. If you can, post some images of what your screen displays with your question. That way we can see what you see. Use this guide 在已经存在的问题里加入图片 for that. Panels that size are hard to come by and may cost more than a new TV. Remove the back of your TV, check all the wires and look for obvious damage to the boards. You should also find a sticker affixed to the panel. That would be the panel number etc. Do an online search with that and see if you locate a replacement panel.
这个答案有帮助吗?
得分 2
添加一条评论
My TV gets loaded and gets off there's no picture shown can u tell what's the problem
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 417
