跳转到主内容
加入维修社区 - 创建账户
于 2017 年 6 月发布,是 Surface Pro 4 的继任者。也被称为 Microsoft Surface Pro 12.3 英寸。型号:FJT-00001。
Heat Gun/Blower for Screen Replacement
I am looking at purchasing a heat/gun blower to replace my Surface pro 5 screen (warm the adhesive to weaken it)....as well as for other electronics.
I have come across 3-in-1 Function Heat Blower and Soldering Iron (see link below), which I thought could be helpful with other projects also.
https://www.jaycar.co.nz/3-in-1-function...
Has anyone had any experience using this type of "heat blower"? First thought is it may be difficult to control the temperature...although it does have a flame adjustment setting.
Thanks in advance for your help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Hi @dgmossman ,
You may wish to take note of the warning at Step.1 in the ifixit Microsoft Surface Pro 5 屏幕更换 guide.
Just a thought.
由完成的
Go for an iopener, otherwise it's too easy to damage the surface.
由完成的
添加一条评论
2个答案
已选择的解决方案
I think the soldering gun you picked will be to narrow an area and far to hot to do the job well. I believe you chances or success on this repair would be much greater with a standard heat gun:
Heat Gun
Loosen adhesive or reflow solder with this 1500W heat gun. Low setting reaches 570 degrees F (300 degrees C). High setting reaches 1112 degrees F (600 degrees C).图片
产品
Heat Gun
$29.99
这个答案有帮助吗?
得分 3
添加一条评论
I would use the iOpener or a heatmat.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Daniel Mossman 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 20
总计 1,693
