跳转到主内容
加入维修社区 - 创建账户
探索各种食品冷却设备的全面维修和拆解指南。这是你排查故障和修理冰箱、冰箱冷柜及其他制冷设备的得力帮手。 无论你是要解决常见问题,还是在寻找特定型号的详细操作步骤,我们的指南都涵盖了保持设备高效运行所需的一切。非常适合 DIY 爱好者和专业维修技术人员。
Freezer section thaws then freezes
Freezer section of my fridge will freeze then hours later I will find it thawing out
Then maybe a few hours later everything is frozen again
Update (04/09/2018)
Yes food thawed
I put a coin on a cup of frozen water
The next day it was at the bottom of the cup
Hence the ice melted and the coin sank so I know for sure it thawed
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
Can the thermistor in the freezer section be randomly send out a false temp or do they just fail completely?
完成的
Hi @mexico1 ,
What is the make and model number of the fridge?
Could be that the defrost timer control is faulty.
Usually when thermistors fail, they fail. Unfortunately sometimes not completely, that would be too easy. They may shift their resistance values which can totally confuse as to what is going on. You have to confirm what their "normal" resistance value should be at what temp and then go from that
完成的
ge profile fridge
prfs2mbxass
hr 305135
完成的
Hi I have this problem too my fridge works fine and my freezer works great for about 8 weeks then it will just defrost the food then I have to switch it off make sure all the ice is gone and then it's works again for another 8 weeks then does the same can anyone help please
完成的
Make sure the fan is not blocked
完成的
添加一条评论
3个答案
最有帮助的答案
Sounds like it is going through the defrost cycle. Is the food actually thawing?
这个答案有帮助吗?
得分 3
添加一条评论
Hi @mexico1 ,
According to this parts list for your model, the defrost action is controlled by the defrost limiter thermostat.
There are however 3 temp thermostats / sensors, the first 2 below are involved with the defrost action
1. Defrost limiter thermostat
2. Defrost thermostat
3. Temperature sensor
The first one may be worth looking at as it controls how "warm" the freezer can get during the defrost cycle.
Measures temperature with an 18-inch wire lead, compatible with various GE refrigerator models.图片
产品
GE Temperature Sensor with 18 in. Wire Leads - WR55X10025
$33.99
Monitors the temperature of the evaporator coil in your refrigerator to prevent frost buildup.图片
产品
General Electric Defrost Thermostat - WR50X10068
$33.99
Regulates the temperature during the defrost cycle in your refrigerator.图片
产品
GE Refrigerator Defrost Thermostat - WR50X10069
$30.99
这个答案有帮助吗?
得分 2
添加一条评论
@krista88 ,
My first thought on your comment was that it was not defrosting properly as you said that you had to turn it off and make sure all the ice is gone.
If the food has thawed why is there still ice there? It should also have melted and drained away.
8 weeks seems to indicate a build up of ice which is interfering with the normal operation of the fridge. With auto defrost there should be no build up as any ice should have been removed during the defrost cycle which occurs once every 8-12 hours
When you say that you have to turn it off, is the fridge compressor running or is it that there is just power connected to the fridge i.e. the interior light works when you open a door, and you don’t want it to start up again?
这个答案有帮助吗?
得分 0
5条评论:
@jayeff I have to turn it off at the mains my make is LG and the model number is GWL 227YBQA there is ice build up a lot and my food half defrosts until the ice has completely gone then freezes again my fridge works perfect
完成的
Hi @krista88 ,
Unfortunately I cannot find any diagnostic tech sheet for you refrigerator or even a comprehensive parts list which may help to identify possible problem components
It definitely sounds like an auto defrost problem, Possible causes for this in no order of priority are:
faulty defrost heater.
blocked drain pipe from freezer to evaporator pan under the refrigerator.
faulty defrost thermostat (or thermistor)
faulty control board
Sorry that I can't be of more help on this one.
完成的
Ok thanks for your help would it be a costly job to call out a repair men does anyone no please
H
完成的
Hi @krista88 ,
Might be easier if you call an authorized LG refrigerator repair service in your location and ask them about call out fees etc and also tell them about the problem and ask about a rough "guesstimate" of what the repair cost may be.
I only suggest an authorized repair service as they should have access to the necessary information about how to test the electronics of the fridge and also the parts if necessary.
Modern refrigerators have diagnostic programs installed which can tell what the problem may be and this reduces the time spent on the repair
完成的
Ok thanks for your help will let u no result
完成的
添加一条评论
添加你的答案
Ron 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 42
总计 11,034
