跳转到主内容
加入维修社区 - 创建账户
1999 年发布,初代 PowerMac G3 的继任机型,主频 300-450 MHz,配备 64 或 128 MB 内存,6 或 12 GB 硬盘
Black Screen with Backtrace and Exceptions
Running OS X 10.4.11 on PowerMac G3. The system is constantly freezing and I have to restart. Often I get a black screen with a long list of backtrace and exceptions.
There is an extremely long stream of info on a black screen. Below I've listed one portion which differs from the rest:
Backtrace:
0x04DF358C
Kernel loadable modules in backtrace (with dependencies)
com.apple.driver.ndrv.ATY.Rage128.0x4df009c(1.0.2f 47)00x4def000
Exception state (sv=0x1D20C780)
PC=0x000AF354; MSR=000081030; DAR=0E02FD000; DSISR=0x42000000; LB=0x000AC134; RI=0x0000B9E0;XCP=0x0000001C (0x700 - Program)
Can anybody help me fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
How much RAM do you have?
完成的
添加一条评论
1个答案
已选择的解决方案
what you're getting is called a kernel panic. start up from your system installation disk, go to the second screen pull down menu to utilities > disk utility and select your drive on the left. run the repair till it runs clear. if this fails, reinstall your system. how much ram do you have?
这个答案有帮助吗?
得分 2
3条评论:
I've only got 288 MB of memory. I've avoided investing too much into the system since it has this problem. If I could just get it to stop freezing up, I might have a chance to get to know and love it. Then I might consider upgrading it.
完成的
I don't have the original system disk that came with the system. I only have the OS X 10.4 installation disks.
完成的
You're running on the minimum amount of RAM. Use the 10.4 disk for repairing the drive.
完成的
添加一条评论
添加你的答案
David 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 660
