跳转到主内容
Repair guides and support for Panasonic's Viera line of televisions.
417 个问题 查看全部
Panasonic TH-42PX75U does not see the horizontal top image
Panasonic TH-42PX75U does not see the horizontal top image. The bottom horizontal image is seen. It has sound. The SU-BOARD TXNSU1HNTU (TNPA4184) may be damaged. This has repair or it will be another area of ​​the tv.
With the TV on I loosen the tapes of the SU1; SU2; SU3; SU4 and horizontally in each of them when moving them out small lines of horizontal colors.
Now clean all the connectors. Thank you and awaiting your response
Actualización (20/03/18)
I want to place an image that shows that half of the top horizontal screen of the TV screen is not displayed. That is the fault. Now check the continuity of the SHIPs of the SU-BOARD TXNSU1HNTU card (TNPA4184) from the SU1; SU2; SU3; SU4 and all are approx. in 8. It will be some component of the SC-BOARD stage.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
@panasonic42 do you get any blink code from your power LED?
完成的
完成的
添加一条评论
1个答案
最有帮助的答案
@panasonic42 you are not telling us if you get any blink code from your power LED. Yes the SU would be the prime suspect since it is responsible for the scanning of the upper half. Post an image of what your board looks like and what your screen display. That way we can see what you see. Use this guide 在已经存在的问题里加入图片 for that.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Guerra 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 1,340
