跳转到主内容
加入维修社区 - 创建账户
Sony Xperia Z4(在欧洲被称为 Sony Xperia Z3+)。这是一款智能手机,配备 5.20 英寸 1080x1920 显示屏,搭载 1.5GHz 处理器、3GB 内存和 2070 万像素后置摄像头。该机型发布于 2014 年。
My phone does not charge
My phone does not charge or turn on, I connect the charger but it does not start the charge, I put the battery in another phone and it works fine. help please that can be. Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi!
I think you should replace the charging port. Maybe the IC has gone bad or something. Follow this guide until step16 to see how.
这个答案有帮助吗?
得分 2
3条评论:
I was looking for the same thing, can this part be?
https://www.aliexpress.com/item/T-Parts-...
or it is about another
由完成的
Yeah that's it!
由完成的
Excellent, I will make the purchase, but most likely it takes 2 months at least to get to Peru, so after that time we will know the result. Thanks for your help.
由完成的
添加一条评论
Check you power connector maybe its loose or Some dirt inside..
这个答案有帮助吗?
得分 1
1条评论:
the phone does not have more than 4 months of use and I have it saved several months ago because it is broken and now I want to repair it. But I doubt it's dirt. Which part do you think is causing this failure?
由完成的
添加一条评论
添加你的答案
jhulion 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 2,637
